1913 Trivia
1913 Trivia
Post by Original Smith » Sat May 13, 2023 10:44 am
I have been writing bits and pieces on 1913's for years, and am needing thoughts others may have on the subject. A few years ago, I purchased an extremely original runabout that was badly restored in the early 1950's. It had the original top and upholstery, but were not savable. I drove it for a couple of years as it was, but decided to do a complete restoration. It has a Fisher body, and there was no indication the body was ever blue. Only traces of black showed up here and there. The original engine had been replaced with a newer type at some point, and a previous owner before me replaced that one with another that had a serial number close to the original. I have registration receipts showing what the original engine number was. Every piece of wood in this car is original, except the tool box in back of the gas tank which was duplicated by me. It must have been removed by a previous owner because the gas tank had to be removed, but that wasn't necessary because it can be removed! I painted the body blue, because I had already purchased the paint, but would have painted it black otherwise.
My main reason for this post is the nuts and bolts, which I've always been interested in. There are many that still have their original brass plating on them to this day. There are too many to list here, but I think this sort of thing is important. What I wonder about is did all five of the body makers do the same thing, or just Fisher?
13 Runabout Top 3.JPG (50.31 KiB) Viewed 1902 times
Last Name: Strange
Re: 1913 Trivia
Post by CudaMan » Sat May 13, 2023 11:01 am
I think Royce has a pretty extensive review of the 1913 model year on his forum (in the members only section). :)
Re: 1913 Trivia
Post by Original Smith » Sat May 13, 2023 11:48 am
Yes, Royce has an extensive knowledge of Model T's. Has anyone noticed Randall Anderson, rip, standing next to my car? In addition, I wrote a section in Bruce's book on 1913's when I was in my twenties. I've learned a few things since then!
Last Name: Strange
Re: 1913 Trivia
Post by CudaMan » Sat May 13, 2023 5:00 pm
OT, but since you brought it up, here is a pic of R.V. and his brother Jon from 2021 Hershey. R.V.'s passing was a tragic loss for the hobby. :(
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: 1913 Trivia
Post by Rich P. Bingham » Sat May 13, 2023 5:06 pm
Larry, it would be helpful to know what hardware you wish to compare. My '13 runabout is a Wilson body, the only brass plated fasteners are the screws and nuts that hold the windshield clamps on the dashboard.
Get a horse !
Last Name: House
Re: 1913 Trivia
Post by George House » Sat May 13, 2023 7:51 pm
I can only help on the 2 tall square nuts fastening the tail lamp bracket. And they were painted black for a ‘14 runabout. I assume the B on the seat riser is for Beaudette.
Re: 1913 Trivia
Post by Original Smith » Mon May 15, 2023 9:57 am
Every nut and bolt that is associated with the firewall is brass plated steel on the above pictured car.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: 1913 Trivia
Post by Rich P. Bingham » Mon May 15, 2023 10:11 am
That is interesting ! I assume that means the heads of step bolts are brass ?
Get a horse !
Last Name: House
Re: 1913 Trivia
Post by George House » Mon May 15, 2023 10:55 am
So Larry, can we assume your ‘13 firewall fastener description would be the same as my above posted ‘14 runabout firewall fasteners ?
Re: 1913 Trivia
Post by Original Smith » Wed May 17, 2023 1:25 pm
All associated firewall bolts are brass plated steel. There are eight bolts that still have the original brass plating. The side light brackets, and the four steering column bolts. The others I had to get replated.
