Windshield hardware
Mopar_man
Last Name: Govoni
Windshield hardware
Post by Mopar_man » Thu Jul 06, 2023 10:34 pm
Getting ready to put the windshield together on my 26 Touring. Looking at a catalog there is no nut but when I got the bolts they came with a nut. Is this toe correct order minus the nut?
Also I thought this drilled area on the bottom of the frame (where the rubber goes) was just a manufacturing mark but now I've seen it on older (original?) frames.
micshotrodgarage
First Name: michael
Last Name: miller
* REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Re: Windshield hardware
Post by micshotrodgarage » Fri Jul 07, 2023 8:52 am
From an old Macs parts catalog illustration; the order you have excluding the nut is correct.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri Jul 07, 2023 12:08 pm
That's what I saw as well. I'm thinking the nut is for another application.
Post by RajoRacer » Fri Jul 07, 2023 12:19 pm
That nut holds the cone to the stud, I believe.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri Jul 07, 2023 12:58 pm
Steve, never thought about that. I try in different configurations and see if the nut will fit into the windshield stanchion.
Post by RajoRacer » Fri Jul 07, 2023 1:54 pm
I believe the stud screws into the frame followed by the cone, the nut & then the w.s. frame then the wingnut.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri Jul 07, 2023 1:55 pm
I'm thinking that's right.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Fri Jul 07, 2023 9:51 pm
That drilled area at the bottom of the frame is the starting point for inserting the windshield rubber.
NY John T
Last Name: Killelea
Post by NY John T » Fri Jul 07, 2023 9:54 pm
agree with Jack Putnam
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri Jul 07, 2023 10:42 pm
Wow! I never would have thought that. Thanks!!!
