Heinz Coils Adjusting Points Help Needed
Vrayfoster
First Name: Victor
Last Name: Foster
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
Board Member Since: 2002
Post by Vrayfoster » Tue Jun 27, 2023 6:53 pm
I have 4 Heinz coils I just acquired. My guess is these are original coils. 3 spark nicely in a buzz box. The 4th one momentarily sparks then stops. The points were upside down so I turned them over with the same results. The points close at about a 20 degree angle, certainly not parallel as they should be. I have no idea what to adjust to get them parallel, set the points, adjust the spring tension, etc. I've read everything I could find on Heinz coils and one of the articles implies the spring should be flat. What spring is that referring too? Any help, or guidance would be greatly appreciated.
Moxie26
Last Name: Jablonski
Re: Heinz Coils Adjusting Points Help Needed
Post by Moxie26 » Wed Jun 28, 2023 2:26 pm
Just look up a previous posted topic about 3 weeks ago entitled "New style coils versus Old style coils". There is a poster that does rebuild and recalibrate Heinz ignition coils and I believe he would be your answer.......... David Woods, ............phone : 1-517-927-9232 . .......Forum name is " Woody23 "
Moxie26
Post by Moxie26 » Sun Jul 02, 2023 3:14 pm
Victor ...... any help yet with your coils ???
Distagon2
Post by Distagon2 » Sun Jul 02, 2023 5:50 pm
I thought Luke Chanell is the Heinz coil guy.
Moxie26
Post by Moxie26 » Sun Jul 02, 2023 7:32 pm
Post Luke's contacts for Vrayfister.
Distagon2
Post by Distagon2 » Sun Jul 02, 2023 7:39 pm
Luke.chennell@gmail.com
Midnight Coil Repair
1130 E. Euclid
McPherson, KS 67460
Sorry don't have a phone number. If you do the Facebook thing, he has a page under Midnight Coil Repair. I have found sending him a Facebook message seems to work the best. YMMV
Moxie26
Post by Moxie26 » Wed Jul 05, 2023 7:18 am
Vrayfoster .... Good morning... has posted information been of any help ?
Vrayfoster
First Name: Victor
Last Name: Foster
Post by Vrayfoster » Thu Jul 06, 2023 4:52 pm
Nope, I still don't know how to adjust the points on Heinze coils. I would like to find a write up like Patterson and Boggess did for the KW coils if one exists.
Moxie26
Post by Moxie26 » Thu Jul 06, 2023 4:58 pm
Moxie26
Post by Moxie26 » Thu Jul 06, 2023 5:01 pm
Good Luck Victor. Two quality contacts were suggested to help, up to you to accept.
Post by Scott_Conger » Thu Jul 06, 2023 5:15 pm
https://www.mtfca.com/discus/messages/7 ... 1484321536
this will provide all of the clues and outright information to accomplish what you want to do, but a buzz box will not be part of testing the results
read carefully and thoroughly - these coils are not set up according to regularly regurgitated convention that applies to the bulk of later coils.
there is so much more to repairing or using a coil than "getting a good spark", and that "so much more" has been covered to pretty much the "nth" degree on the forum. A search on GOOGLE "Mtfca Heinze coil" will yield a plethora of information (much like the link I supplied above)
you're not working with the easiest coils, for sure, and unless fully tested, supplied with a replacement cap and excellent or reproduction points and adjusted correctly, they are going to be less than great performers (as a set). To achieve a high level of performance individually and then get them to perform adequately in the car as a "set", you're going to have to invest more $$ in test equipment than the cost to send them out for warranted rebuilding.
MKossor
Last Name: Kossor
Post by MKossor » Thu Jul 06, 2023 6:14 pm
Here is another link I think you may find informative and of interest about Heinze coils.
viewtopic.php?f=2&t=26730&p=205560
