Too many accessories, not enough room!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Jun 15, 2023 7:38 pm
Asking for a friend… I swear!😉
He has a ‘15 touring (pre generator block) that apparently needs a water pump. The desire is to get away from magneto lights, and install a charging system and battery. Does anyone have any examples of an alternator and water pump on an early engine? Did you use 1 belt or 2?
Les Schubert
First Name: Les
Last Name: Schubert
Re: Too many accessories, not enough room!
Post by Les Schubert » Thu Jun 15, 2023 8:12 pm
I suppose a electric drive water pump could be a solution?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Jun 15, 2023 10:52 pm
A further thought is that the water pump requires very little energy so I think that one belt could drive it all.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Thu Jun 15, 2023 11:17 pm
Although I prefer a stock set-up, I can understand wanting an alternator on a pre-1919 Ford so you can maintain a battery for a starter, headlights, turn signals and other accessories. Bob Coiro's '15 touring comes to mind.
However, does your friend really need a waterpump?
All the alternator set-ups on pre-1919 engines that I have seen posted on the forum over the years are located on the driver's side. When that is the case, there is no room for a waterpump.
Post by Allan » Fri Jun 16, 2023 3:55 am
If we were to attempt to fit an alternator on the driver's side, the inlet manifold and carburettor would get in the way. Now, if were to mount it on the left side............
Last Name: Wrenn
Post by TWrenn » Fri Jun 16, 2023 8:25 am
A better thought is to figure out WHY it needs a water pump and then correct that issue and the rest is easy. Besides, the alternator goes on the opposite side of the engine from a water pump anyway, why would that be an issue? I'd still correct the apparent cooling problem and run the car "au natural" as it was designed and 99.9% do without problems.
Post by John kuehn » Fri Jun 16, 2023 8:53 am
That’s a good thought is to why the need of a water pump. What is the condition of the radiator. Is the engine having a boil over? When is the last time the head was off and is the block water jacket have to much sludge or rust.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Fri Jun 16, 2023 9:14 am
Not enough room" EGADS and horrors!! You just need more cars for your goodies!!!!!
Last Name: Wrenn
Post by TWrenn » Fri Jun 16, 2023 10:29 am
:lol: yeh I ended up that way a while back...picture SIX..yes six cars...5 T's and a model A...one T was a firetruck..crammed in my 24'x50' barn! Eventually I thinned the herd down to just 3 T's, and one of them stays in the house garage!
Post by RajoRacer » Fri Jun 16, 2023 10:40 am
Here's an alternator kit on our '14 - be tough to fit a water circulator in the midst !
jsaylor
Last Name: Saylor
Post by jsaylor » Fri Jun 16, 2023 11:43 am
Just use the diode-1156 bulb design to charge the battery from the mag. If a lot of night driving, then use LED head lights.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Jun 16, 2023 8:42 pm
Thanks for the input fellas! I’m hoping to NOT go overboard on this project…🙄. I have been eyeballing the head mounted option but having a hard time envisioning the belt routing. Steve, your pic of the dual belts gives me hope, is your crank pulley a modified aluminum repro?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Jun 16, 2023 9:40 pm
I have made a “polyvee” pulley for the fan and with one for the water pump I think you can drive it all in one “loop”!!
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Sat Jun 17, 2023 4:11 am
If you really want to shoehorn a water shover in the mix, I'm thinking an Atlas pump may be the way to go... I like them better than most because they live down at the bottom of your radiator outlet, instead of next to the block inlet, so the risk of cavitation is minimal. Just my 2¢... Sus
Post by Mark Gregush » Sat Jun 17, 2023 12:13 pm
An Atlas might work.
Post by RajoRacer » Sat Jun 17, 2023 1:51 pm
It was the pulley that came with the TTP kit Kevin. I agree with the Atlas circulator suggestion - could be a viable option. I might even have enough of them to make one or two if interested.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Jun 17, 2023 2:56 pm
Thanks for the offer Steve! I haven’t even seen the car yet due to traveling for work the last several weeks, and will be on the road to Lincoln for 2 more. Will try to get the fella to mock up my old speedster alternator while I’m on the road to see if it fits. Then we can deal with the belts…
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Post by Cordes_jeff » Sun Jul 09, 2023 10:15 am
I've run a pump and alternator on a pre-generator car before. Ran it on one belt as well all on the driver side of the engine.
