Miss on battery
Russ T Fender
Topic author - Posts: 475
- First Name: Val
- Last Name: Soupios
Miss on battery
My '27 will start on battery but runs rough. It idles smoothly on battery once started but misses when you rev it up. Adjusting the spark lever makes little or no difference. When I switch to mag it clears up and runs fine. The battery is good and cranks the starter over without any problem. Any suggestions?
Re: Miss on battery
If your battery is fully charged and in good condition, I'd check the spark plugs and timer. If those are good, you may need the coils adjusted.
An ignition switch problem is a possibility.
Re: Miss on battery
Have the coils tuned. Best guess is the amp draw is a bit high. The ignition system is happier running on the higher mag voltage. This is typical.
T's run poorly on 6V.
Re: Miss on battery
Most T's require somewhat of a warm-up to smooth out, on Bat or Mag. Could be the miss is part of the run-up.
Might try to clean the timer rotor and case. Or clean the plugs for the lower output that 6v has on the coils.
But may be one or more coils isn't liking the 6v, so perhaps have all 4 checked, or fixed to fire on time, best done with the ECCT.
My T's will run on 6v, but on road speed if I forget to flip to MAG, with the performance down, usually wonder why acceleration is off, and I glance at the switch panel key and go "duh"
Russ T Fender
- First Name: Val
Re: Miss on battery
Thanks for the suggestions. I will switch out the coils from another one of my T's first and see if that doesn't clear it up. If not then I'll work on the timer.
Re: Miss on battery
Another thing to consider when running on battery is that once the engine is started, the timing will need to be advanced immediately, and usually quite a bit more than may be required when running on magneto at similar engine speeds.
Re: Miss on battery
Does it still miss occasionally after a warm up on battery? If it does try adjusting the carb slowly and then rev it up on battery. Other than that probably a coil issue. Even the best running cars will sometime miss a bit until a warm up. A regularly driven car will usually run the best than one thats an occasionally driver.
And as always T’s run best on Mag.
Re: Miss on battery
I think it is the adjustment of the coils. I drove one for about 5 years on 6V battery and it ran smooth but not as much power as on magneto. This happened because the funnel broke off the oil line and cut the mag coils. Fortunately I had a magneto plug oil line and no problems with the oil. Later I rewound a mag ring and fixed it. That was when I found out what had caused the magneto to fail.
If you are driving along and realize you didn't switch the key to mag, don't switch while moving. in gear. Put in neutral and idle the engine. Otherwise there is a chance you will blow the muffler.
Russ T Fender
- First Name: Val
Re: Miss on battery
Went to swap coils and found that that the coils from my '14 just won't fit in the '27 coil box. Don't understand why that would be as they are all Ford script or K&W coils. Even the coils I had in the '27 coil box are a very tight fit but I was able to get them out one at a time eventually. I found a few extra coils that I had which I could get in the box with no small amount of effort and that cleared up the problem I was having running on battery but I am still puzzled by the fact that the coils from my '14 would not fit. I always thought that Ford coils and K&W coils were interchangeable and were a standard size.
Re: Miss on battery
Coils that have been overheated may be slightly oversize or otherwise distorted. Coil boxes can vary, also. Some coils have prominent solder contact buttons, and some do not.
Kerry
- Last Name: van Ekeren
Re: Miss on battery
Don't like the way your car starts on battery?
runs fine on mag, simple fix,
follow Fords manual instructions on how to start engine and use magneto.
Russ T Fender
- First Name: Val
Re: Miss on battery
That's what I was doing after the problem started but I never had an issue before and I wanted to find the source of the problem and correct it. I rarely use the starter and usually crank start on battery but my back is not up to crank starting on mag so I wanted the problem resolved. Always started on battery before with the hand crank and ran well enough before I switched to mag.
