Tire pump
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Tire pump
Post by Will_Vanderburg » Tue Jul 04, 2023 2:05 pm
Spent some time refurbishing my tire pump. Cylinder all smooth and shiny.
Forgive the modern hose clamps. I cleaned the hose to tube connection. It was clogged tight. It pumps air and does inflate a bicycle tube. There’s no ball bearing in it. And I didn’t remove the valve plunger.
What color should the base be? Right now it’s red oxide.
William L Vanderburg
1922 Center Door Sedan
Re: Tire pump
Post by Steve Jelf » Tue Jul 04, 2023 3:10 pm
Don't bet the farm on this, but I think all black would be correct. I left the tube polished brass, but I think it's incorrect. My version of "natural" wheels. :D
I was pleasantly surprised to find that the local Ace Hardware had the old style compression clamps you loosen with pliers to install.
These pumps were made without a check valve and with a chuck that had no center post, relying on the tube's stem valve to keep the pressure in the tire. I don't understand how your pump can work with a center post in the chuck.
Will_Vanderburg
First Name: William
Re: Tire pump
Post by Will_Vanderburg » Tue Jul 04, 2023 3:36 pm
There’s a tiny hole in the side of the center post of the chuck
Will_Vanderburg
First Name: William
Re: Tire pump
Post by Will_Vanderburg » Tue Jul 04, 2023 3:39 pm
Steve,
Can you post a pic of the clamps you speak of?
Re: Tire pump
Post by Steve Jelf » Tue Jul 04, 2023 4:24 pm
At the pump end of the hose is a clamp from the hardware store.
At the other end I have twisted baling wire. I'm not sure why. I probably broke the real clamp trying to install it.
Will_Vanderburg
First Name: William
Re: Tire pump
Post by Will_Vanderburg » Tue Jul 04, 2023 5:26 pm
When I removed my chuck to clean it, it was secured with wire as well.
Re: Tire pump
Post by Steve Jelf » Wed Jul 05, 2023 12:53 am
The standard Ford repair kit. :)
Will_Vanderburg
First Name: William
Re: Tire pump
Post by Will_Vanderburg » Sat Jul 15, 2023 8:49 pm
I took the pump again and tried to pump up a hand truck tire. It does pump it up, but I do notice there is some air being sucked back out of the tire. A small amount.
There was no ball bearing in the pump but the chuck does have the center post. I’m going to get a bearing and see if that stops the leakage.
I really don’t want to destroy an original chuck. I do know chucks are available without the center post. Maybe I’ll try that.
Re: Tire pump
Post by Allan » Sat Jul 15, 2023 9:36 pm
As Steve said, the centre post is there to depress the valve core centre to allow air to enter. While it is depressed any air pumped in is free to escape.
You need to either remove the centre stem in the chuck, or fit a non return valve at the pump end of the hose.
Re: Tire pump
Post by Steve Jelf » Sun Jul 16, 2023 12:26 am
Yes, I found them online pretty easily.
Re: Tire pump
Post by TXGOAT2 » Sun Jul 16, 2023 9:24 am
I believe the tire pump would be more efficient with a check valve at the pump end of the hose. That way, you would not lose the small volume of compressed air in the hose with every stroke.
