Heinze/KW hybrid
Woody23
First Name: David
Last Name: Woods
Heinze/KW hybrid
Post by Woody23 » Thu Jul 27, 2023 9:25 pm
I recently completed a coil project for a ‘13 T. The owner has a Heinze box but wanted KW style coils. So four fresh wood boxes in the form of Heinze but KW points and coils. This is a great option for touring. Use the KW’s for touring and keep the Heinze for show.
David Woods
Williamston T Works (Facebook)
Re: Heinze/KW hybrid
Post by Scott_Conger » Thu Jul 27, 2023 9:31 pm
well done :)
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Thu Jul 27, 2023 9:52 pm
David, that’s awesome & nice looking too.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Jul 28, 2023 1:23 am
Well done, indeed!
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Fri Jul 28, 2023 2:36 am
THAT is impressive!!! Well done!
Distagon2
Post by Distagon2 » Fri Jul 28, 2023 6:59 am
That is exactly what I should do for my 1912 (I have Heinz coils). I don't know if this is a service you might offer, but I would be interested in a set of coils like that.
Woody23
First Name: David
Last Name: Woods
Post by Woody23 » Fri Jul 28, 2023 7:26 am
I do, I build a lot of these KW conversions. I also build KIngston coils. I attached a few more photos and post other projects on Facebook under Williamston T Works.
You can contact me at 517-927-9232 or dwtworks@gmail.com
Post by Original Smith » Fri Jul 28, 2023 10:57 am
I can remember when we had to do that, but then RV started making the correct points. Since the KW points are more common, it probably still isn't a bad idea. I've always used KW coil boxes in my 13's anyway, and like them. RV made me a brand new '13 KW coil from a junk one a few years ago. I have it in my living room on top of my display cabinet. From my own experience, I have found the original 1913 KW coils to be very reliable without having to do anything to them.
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Fri Jul 28, 2023 11:23 am
Email sent.
Post by Allan » Sat Jul 29, 2023 8:58 pm
Where we you when I went to a Truefire system in 1994 when my chocolate van hit the road? Not that I have ever had any trouble with the True fire, but I did wind my stock of working Heinze coils down from seven to three, before I fitted it. While the True fire continues with its excellent performance, I should probably make alternative arrangements as an insurance policy.
