What do I have here
Chip Moore
First Name: CHIP
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: 1915 3-DOOR TOURER
Board Member Since: 2023
What do I have here
Post by Chip Moore » Wed Aug 16, 2023 1:56 pm
I purchased this split-rim wheel from a local auction, thinking it was probably for a Model TT given the 1/2" wide dual key slots. The wheel measure 23" in diameter and the rim 2". The hubs are 6" in diameter and appear threaded for a Model T hub cover.
Any ideas? Rarity/Vaue?
Thanks, Chip
Re: What do I have here
Post by speedytinc » Wed Aug 16, 2023 2:09 pm
You did not hit the lottery.
This is a common, early version of a model T demount-able wheel '19,20
Post by Scott_Conger » Wed Aug 16, 2023 2:27 pm
John's right, and Given that it is a loose-lug wheel, the overwhelming likelihood it is a common Kelsey Wheel
It's value is what you paid for it. Hopefully, you needed it.
Chip Moore
First Name: CHIP
Last Name: MOORE
Post by Chip Moore » Wed Aug 16, 2023 9:33 pm
Thanks for your reply. No, I don't need it, but for $22 I couldn't pass it up.
Post by Scott_Conger » Wed Aug 16, 2023 9:52 pm
I have a friend who used one to create the top platform for a glass table (with hole in center for the hub) for a nice drink table for his Man-Cave. Looks great!
Perhaps you can find some interesting and useful thing, too... ;)
Last Name: Strange
Post by CudaMan » Wed Aug 16, 2023 11:22 pm
Yep, Kelsey front wheel, maybe someone on the forum will contact you offering to buy it (not me, my '24 has Hayes wheels). :)
Post by Allan » Thu Aug 17, 2023 3:51 am
Chip, others have identified the wheel for you, but no-one pointed out that it is not for a split rim. It takes a clincher rim with no mounting lugs. The only model T wood wheel which takes a split rim is the 21" wheel on the 26-7 improved model T. Nice find though. May be Canadian if the spokes taper differently at the hub.
Chip Moore
First Name: CHIP
Last Name: MOORE
Post by Chip Moore » Thu Aug 17, 2023 11:37 am
Thanks for the info. I was actually just online looking for wagon wheel chandelier ideas and may do something with it without damaging it. I'm new to the Model T family and am in the learning mode.
Post by Jerry VanOoteghem » Thu Aug 17, 2023 11:47 am
Welcome Chip!
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Thu Aug 17, 2023 12:22 pm
Welcome Chip, great idea! You could mount four or five headlight buckets pointing down and hang it by an old wishbone. :D
Post by speedytinc » Thu Aug 17, 2023 12:24 pm
They make neat wall clocks.
