Length Simmons spray needle valve
Topic author - Posts: 5437
Anyone know the correct length of the spray needle valve for the Simmons type carburetor? Need to trim back a NH needle to use.
Re: Length Simmons spray needle valve
Also notice the small difference in the brass rod below the threads.
It probably doesn't matter much, but something to keep in mind.
Thank you! Don't know if the little bit of brass will be an issue, but as it is part of the crimp that keep the parts together I think I will leave it.
