Odd Clincher Rim
Scott C.
Topic author - Posts: 864
- Last Name: Clements
Odd Clincher Rim
What is this single lug rim?
- Last Name: Strange
- Board Member Since: 2013
Re: Odd Clincher Rim
Kelsey 88. Uses loose lugs with flat bottom lug nuts. The one lug indexes on one of the lug bolts to keep the rim from spinning on the felloe.
I believe its the correct rim for the wheel in "what do I have here?" post. Early rim for the 19-20 wheel.
