23-5 top bow work on 26-7 body???
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Mon Dec 04, 2023 3:18 pm
Have set of top irons forsale that they where late style but seems they are earlier had lots inquiries
If they would even ot correct ???
First Name: john
Last Name: karvaly
Re: 23-5 top bow work on 26-7 body???
Post by speedytinc » Mon Dec 04, 2023 3:44 pm
Your set seems really screwy.
Its too complicated for a roadster.
It most like a 27 touring, except its missing a bow? & the body attach point bow should be curved.
Post by Jerry VanOoteghem » Mon Dec 04, 2023 4:11 pm
They look fine to me for a 23-25 Roadster.
Post by Norman Kling » Mon Dec 04, 2023 4:24 pm
I have a 26 Roadster but it has earlier bows, most likely 25. They fit fine and the top works, however, it is more straight in back than it would be with the correct bows. See picture
e
Nv Bob
First Name: Bob
Post by Nv Bob » Mon Dec 04, 2023 11:02 pm
Roadster for sure
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Tue Dec 05, 2023 7:41 am
Bob like I posted in the classifieds. If you look you’ll see the thin supports that strengthens the total assembly as in a set of sockets for a touring. Maybe someone made those or it’s for another style car. The 23-25 roadster sockets are a simple affair. 3 sockets on each side, no metal webbing between the sockets. Straight & clean. Below are pictures of the sockets mounted on the tub of a 1923-5 roadster or cut off roadster can’t tell for sure. I believe these are from the build Mark Strange was doing. Hope you don’t mind me using them Mark. Best John
First Name: john
Last Name: karvaly
Post by speedytinc » Tue Dec 05, 2023 8:22 am
Roadster for sure
Yes, but for what make?
Nv Bob
First Name: Bob
Post by Nv Bob » Tue Dec 05, 2023 10:48 pm
Well not T but several said there A 28-9
So pulled the ad
