KC Warford ratios vs Muncie
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Wed Sep 06, 2023 3:14 pm
Howdy, I am trying to find out how the gear ratios of a Muncie and a KC Warford compare. I am looking for the ratio of the transmission not the final ratios at the rear diff. Any help would be greatly appreciated. Thanks Dennis
Re: KC Warford ratios vs Muncie
Post by Allan » Wed Sep 06, 2023 7:00 pm
Dennis, Layne, the makers of the KC Warford can help. There are different ratios for different applications. I have seen a chart illustrating these but cannot reference it.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Sep 07, 2023 8:15 am
jsaylor
Last Name: Saylor
Post by jsaylor » Thu Sep 07, 2023 12:24 pm
I have seen the KC Warford ad in the Vintage Ford showing the different ratios. For the Muncie, you can turn the input shaft and count the output revolutions to get the ratio.
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Sep 07, 2023 1:14 pm
This may help.
Aux-ratio.pdf
(8.23 KiB) Downloaded 87 times
The KC Warford add has their gear ratios
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Fri Sep 08, 2023 8:13 pm
Thank you all for the ratio info, it is what I was looking for.
