What Overhead is this?
Post by Rich Eagle » Tue Jun 27, 2023 1:44 pm
I can't seem to find the make or model of this overhead setup. Most rockers are on shared shafts rather than separate standoffs.
I don't see a outlet to the radfiator either.
Curious.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: What Overhead is this?
Post by ThreePedalTapDancer » Tue Jun 27, 2023 7:02 pm
That’s interesting. It looks familiar but I can’t place where I’ve seen one before. It has subtle similarities to Rajo but it’s not. I believe the water outlet is in the center where the rag is stuffed, and a pipe/water manifold led to the radiator inlet. Hmmm
OldFord
Last Name: Iaccino
Post by OldFord » Tue Jun 27, 2023 8:07 pm
Might be a HAL conversion without the rocker cover.
Frank
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jun 27, 2023 8:19 pm
The only HAL heads for a T that I know of are the earlier production “run in oil”, and the Akron-Hed. Definitely not either of these.
These same pics surfaced a while back… and as I recall did not get identified. I was just cruising the Speedway museum a couple days ago, and did not see anything with exhaust ports like this one. It’s a neat design, sure would like to see more of it!
T4Tom
Last Name: Magee
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster
Post by T4Tom » Tue Jun 27, 2023 9:15 pm
It looks like the head is mounted backwards! The red arrow is pointing to what looks like the water outlet flange.
Tom
Post by Rich Eagle » Tue Jun 27, 2023 10:11 pm
Thanks, I will try to get some more pictures of it.
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Tue Jun 27, 2023 10:16 pm
No, it can't really be on backwards; the cam is on the right, the rockers have to stay there, too.
ModelTSpeedster
First Name: Randy
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1910 Speedster, 1915 Speedster, 1924 Roadster, 1926 TT, 1923 boattail (project)
Post by ModelTSpeedster » Wed Jun 28, 2023 7:51 am
Here is the HAL version.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Jun 28, 2023 9:39 am
There is quite a few oddball OHV heads out there, whose makers are lost to time. They are often not crude in their design, and very few were made, if not one-off. Another mystery.
Post by Rich Eagle » Wed Jun 28, 2023 9:57 am
Thanks for the speculation. I am trying to decide if I need another project. It's in a car that doesn't attract me but might be worth it for the head and some of the parts. I need to go and see it. If not, I'll pass the information on in case someone else is interested.
Post by Rich Eagle » Thu Sep 07, 2023 5:13 pm
I answered the question of "where does the water exit the head". It is in the top and center and was obscured by a rag in other photos.
I can see no markings or name to who made this head. It may be early with the somewhat crude rockers and standoffs. The push rod adjustments seem like an earlier idea too.
Anyone else have any thoughts or information?
Or have I stumped the band? :lol:
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Sep 07, 2023 5:53 pm
Looks a lot like an early Liberty Head.., They were used on boats for the most part. Thats why there is a center return on the water outlet. Not very efficient for a car with a radiator since early boats used a forced scoop system.
Hank
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Post by kmatt2 » Thu Sep 07, 2023 8:51 pm
I thought the exhaust ports looked a lot like a Robert Roof head I saw a long time ago, but I wasn’t sure. Robert Roof also used the name Liberty , so that would be another name for the same thing. With the stock T water inlet location in the block and having the water outlet in the top of the head , it could be problematic in getting good cooling in the rear of the head if used in a car. In a boat engine that cooling would not be problematic because of the constant cold water intake and no radiator.
kmatt2
First Name: Kevin
I am sure it could be made to cool ok in a car with some sort of baffle and maybe a water pump.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Thu Sep 07, 2023 9:00 pm
Hank
Roof liberty? I have one here, 3 port exhaust, front outlet, 2 port intake.
Post by Rich Eagle » Sun Sep 10, 2023 6:56 pm
FWIW, REO used similar rocker arm mounts with the yoke and threaded into the head for several years. Rollers on the rockers is interesting.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun Sep 10, 2023 7:44 pm
Yeah, I would put money on it being a marine accessory head. There’s many an obscure accessory head sold in catalogues back in the day, we tend to only recognize the major successful manufacturers though.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Sun Sep 10, 2023 8:19 pm
Rockers appear to be on individual stands and separate, not shared.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Sep 11, 2023 9:58 am
I’d like to add, this is the fascinating part of the hobby, when an unusual or long forgotten accessory shows up. It fun trying to identify a real head scratcher.
Post by Rich Eagle » Mon Sep 11, 2023 1:05 pm
Searching for the odd stuff is fun. I often get sidetracked on other odd stuff I wouldn't see otherwise. This head is fascinating.
I hope we find out what it is.
