American to Britsh Car Terms & reverse
Post by TRDxB2 » Sun Sep 17, 2023 12:48 pm
Click on image to see in new window & the click again to enlarge
American to British
British to American
Zebra crossings have two sets of flashing amber beacons (known as ‘Belisha beacons’ after the Liberal politician Leslie Hore-Belisha, who introduced them to crossings in 1934). They have an area of road between them that’s painted in black and white stripes. Drivers are legally obliged to give way to pedestrians on the crossing, so make sure you scan the road ahead and manage your speed as you approach. Remember: zebra crossings do not have traffic lights but they do have a broken 'give way' line that you must not cross when you stop. Failing to give way to pedestrians is a criminal offence that can result in points on a driving licence – even a provisional licence – so it’s worth getting to know the rules.
Pelican crossings differ from zebra crossings in that the flow of traffic is controlled by traffic lights. (And, as far as I know, they were not named after a politician called Mr Pelican.) Pedestrians waiting at a pelican crossing are able to press a button that changes the traffic lights to red. Sounds simple enough – pedestrians press the button and cross once the lights are red. Well, in theory it is simple, but accidents can and do occur as a result of drivers misunderstanding the light sequence or just not seeing pedestrians.
Light duties Unless there are people already on the crossing, you can keep going if the lights are green, even if there are people waiting to cross. But, if you see pedestrians waiting, do not suddenly accelerate to get through the crossing before the lights change. Approach carefully and make sure you scan ahead. The lights will change to amber and then to red, as normal.
The lights will then remain on red for a set period before changing to flashing amber. This is to allow people time to finish crossing. The flashing amber light means you’re free to continue if – and only if – the crossing is clear. If there are still pedestrians on the crossing, you must not move forward until they've safely crossed to the far pavement.
Pelicans and puffins are essentially the same (try telling that to an ornithologist!), except that a puffin crossing has its sequences controlled by sensors mounted on the lights, rather than a timer. These sensors can detect whether any pedestrians are on the crossing and control the colour of the lights accordingly. Once the control button has been pressed, the lights will only change back to green once the crossing is clear. A puffin crossing does not have a flashing amber phase; you have to wait until the lights turn green before you move off.
Toucan crossings This is a surprise crossing we did not mention at the beginning, but it’s worth knowing about. Toucan crossings are designed for pedestrians and cyclists to use at the same time. That’s not to say that cyclists cannot use zebra, pelican and puffin crossings, but they should get off their bikes and wheel them across. With a toucan crossing, the area is wider, leaving plenty of room for cyclists to ride across.
John Codman
Last Name: Codman
Re: American to Britsh Car Terms & reverse
Post by John Codman » Sun Sep 17, 2023 1:34 pm
The way I was taught, an (American) Alligator clip and a Crocodile clip are two different things.
Post by TRDxB2 » Sun Sep 17, 2023 3:51 pm
How so?
Searching the internet they say they are "essentially" the same, and most pictures using the term show no difference. However, the jaws of the crocodile are hinged to open the top jaw, while alligators open their bottom. Also alligators have a wide upper jaw, which allows for the teeth to remain hidden in the mouth while a Crocodile's upper and lower jaws are the same size, exposing their teeth as they interlock, creating the look of a toothy grin.Having said that, alligator clips are mislabeled since the top jaw is hinged and should be called crocodile clips (British correct).
John Codman
Last Name: Codman
Post by John Codman » Mon Sep 18, 2023 12:50 pm
Alligator clips are what are pictured in the photos. Crocodile clips have all of the teeth across a flat front, and a visible true coil spring to keep them
closed. The Jaws cross each other before you get to the teeth.
