Shiny Carburetors
Mark Osterman
Last Name: Osterman
Shiny Carburetors
Post by Mark Osterman » Sat May 18, 2019 9:47 pm
Depending on the look of the entire car, some people like a very shiny brass / bronze carburetor and others prefer the dark brown that comes from time and use. So when carburetors are polished, what is generally used to keep them shiny ... spray lacquer?
Ruxstel24
Last Name: Hanlon
Re: Shiny Carburetors
Post by Ruxstel24 » Sun May 19, 2019 10:06 am
Gas eats most lacquer...
Post by Steve Jelf » Sun May 19, 2019 10:07 am
I dislike lacquer on brass or bronze. It will preserve the shine, but eventually when you have to remove it (you will), it's the job from Hell. For me, the way to keep it polished is to polish it again.
A bronze Holley G shines up very nicely with a little Dremel wire brush.
If I want to keep it shiny I'll take it out and hit it with the brush again next winter.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Sun May 19, 2019 10:15 am
I have used high temp clear engine spray paint on other brass fittings and carbs
This clear resists oil grease and gas
But like Steve Heff states ciated brass looks just like coated brass and over time wears and looks nasty
Post by Original Smith » Sun May 19, 2019 10:18 am
I have enough trouble keeping the radiator shined!
Last Name: Wrenn
Post by TWrenn » Sun May 19, 2019 1:10 pm
I'll second that one Larry! Besides, now all I have are nice black NH's anyway. :lol:
Post by Mark Gregush » Sun May 19, 2019 1:30 pm
I don't go for the real shinny look, don't think they ever were highly polished anyway (bowls maybe), but sure look nice when done that way. I glass bead, then then let them age in place.
Last Name: House
Post by George House » Sun May 19, 2019 7:29 pm
Mark; you initially asked “What is generally used to keep them shiny”... In my case it’s a fireplace mantle:
Post by John kuehn » Mon May 20, 2019 8:54 am
Most likely the brass carbs were clean and in their original unpolished condition when installed at the factory. Sort of like brass fittings as you find them in bins at the hardware store. Clean but “shined” up. As time went on they turned like any other brass fitting being used.
