I've been working on a junk 1918 engine for close to 18 months now. When I say junk, I mean JUNK as the serial number had been roughly chiseled off years ago. To make a long story short, everything needed replacement in addition to rebuilding.
I've had the flywheel on and off quite a few times in order to set my magnet clearances, so the transmission drum assembly sat on the bench for awhile. When it came time to place it back on the main shaft, it was tight. So tight I had to "urge" it down with a copper hammer, thinking it would loosen up when it seated. Not so. Oh, it turned but took more effort than when I first installed it. Here comes the stupid part....
I spend several hours building a 3 arm puller to remove the drums. I began pulling and it moved, then froze. I applied a tiny bit more force and heard a pop. Quick examination showed that one of my puller arms broke a piece off the slow speed drum flange about 3/8" long. The drum surface itself was NOT injured but now I have a nice chunk missing from the flange. I was (and still am) pretty upset
Now, the question: Could I successfully run the drum if I carefully dress the broken portion to avoid hurting the linings, or should I just cuss a bit more and buy another replacement? I considered brazing, welding, etc. but that flange is very thin and I'm sure the heat would probably warp the drum.
Oh, what caused my brand new transmission bushings to suddenly get "tight"? In two words, assembly grease. The bushings were bored to a .003" fit if I recall, and the original grease hardened a bit while the drums were sitting on the bench (about two months). That grease is very soft, but it didn't take much to gum up the works! Next time, plain oil................
