I am restoring a 1914 Ford roadster and am looking for a drawing that shows and gives the dimensions of the steering column slot. I did find a print of the early dash but the writing was so small and blurry that I can't read it. Anyone have a copy of the factory blueprint? Thank you
Craig
Need firewall drawing information
Topic author - Posts: 183
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
- First Name: Mike
- Last Name: Bird
Re: Need firewall drawing information
Craig,
You can view the actual blue print online in a high res drawing. The drawing can be found on The Henry Ford Archive site
Here is the link to the digitized drawing.
https://www.thehenryford.org/collection ... =gs-391753
If you want to purchase the drawing you can purchase any of the drawings that have been digitized online for $7 per drawing.
If you have a factory number of a drawing that has not been digitized the cost is $30 per drawing. If you don't know what the factory drawing may be, email the fine folks over at The Henry Ford (here is the email: ask@thehenryford.libanswers.com) and they will help you find what you're looking for.
Jim Orr is the guy you're going to want to speak to. If you don't hear back from them in a few days that's normal.
- First Name: Craig
- Last Name: Luton
Thank you Tbird for the information, it is just what I was looking for. I will save the link for anything else I may need in the future. Craig
