Previously I have used sections of a reverse gear bush to rebuild brass truss rod mountings where the spring leaf hanging from worn shackles wears a groove in the mounting bracket.
Today I used another piece of the same bush to repair a broken bottom radiator outlet
The piece was shaped and silver soldered in place.
I used to put them in the scrap bin but glad this one hadn't made it.
Another use for reverse gear bushes.
Topic author - Posts: 7315
- First Name: craig
- Last Name: leach
Re: Another use for reverse gear bushes.
Thumbs up on that.
AndyClary
- First Name: Andrew
- Last Name: Clary
Never throw out an old bushing.
Andy
Andy
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Another use for a reverse bushing.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
That's really neat Bob. Are there laws governing the height or rear lamps in Washington? Here I could mount those to the top support arms to act as eye level brake lights. I love the red tourer. My 15 tourer was also red, a little more maroon than yours.
BE_ZERO_BE
- First Name: BOB
I am not aware of any laws concerning tail light height.
The reason that I extended the light below the top cradle
was to make the light visible when the top is folded down.
Be_Zero_Be
Be_Zero_Be
That makes sense.
