VIDEO: Champion X Spark Plugs
ModelTMitch
First Name: Mitch
Last Name: Taylor
* REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
Post by ModelTMitch » Mon Nov 20, 2023 3:01 am
So recently one of my decade-old Champion X plugs finally broke its brass contact post.
I figured, why not splash out on a brand new set of Champion X plugs! ... A bit on the expensive side at AUD$100 EACH, and getting them to Australia but hey that's life!
Here's the video anyway, enjoy! :D
https://www.youtube.com/watch?v=7a017hn3JHg
☆☆ ModelTMitch ☆☆
★ Website: https://www.fordmodelt.net
★ YouTube: https://www.youtube.com/@ModelTMitch
★ Twitter: https://www.twitter.com/modeltmitch
★ Car Club: https://www.glhac.org
Re: VIDEO: Champion X Spark Plugs
Post by DanTreace » Mon Nov 20, 2023 11:18 am
Mitch
Very nice review of Champion plugs.
Anyways fun to watch your YouTube videos! ;)
Did note at sometime, someone, used pliers on those tiny thumb nuts. That can cause real issue with the modern Champion 25s that have an alum. terminal. That terminal is just a short one, and ceramic potted to the insulator. Any real pressure on twisting the terminal nut will bust it apart!
Ford Service tells the proper way to tighten, just with fingers on run down thumb nut, and push the wire lead to snug up, no pliers needed.
Wire lead pushed clockwise will snug up just fine.
ModelTMitch
First Name: Mitch
Last Name: Taylor
Post by ModelTMitch » Thu Nov 23, 2023 6:42 am
I must admit I did use small pliers on the old ones a couple of times, even on the Champion 25 I used as a spare. Bad move! Thanks for the tip 🙂 my leads sometimes still felt loose doing them by hand 🤔
Mitch
☆☆ ModelTMitch ☆☆
