running board iron support adjustments
popeyet
First Name: CHRIS
Last Name: MCINTYRE
* REQUIRED* Type and Year of Model Ts owned: 21 touring, 15 roadster
Board Member Since: 2023
Post by popeyet » Mon Dec 04, 2023 1:42 am
I am rebuilding a 1915 T runabout. I have acquired a very nice frame but am having to install the supports for the running boards. The will each need some adjustments as they are used parts out of a pile of parts. I looked up earlier discussions and found some that are over ten years old. There is reference to factory drawings that detail the specs on where the supports should be to correctly align the running boards so the fenders and apron will fit correctly.
Can anyone help me with this? there was a link to a page with a PDF file but it seems to have gone away on the internet.
Thanks.
williamcournoyer
First Name: William
Last Name: Cournoyer
Re: running board iron support adjustments
Post by williamcournoyer » Mon Dec 04, 2023 3:35 am
I am rebuilding a 1915 T runabout. I have acquired a very nice frame but am havingsmash karts to install the supports for the running boards. The will each need some adjustments as they are used parts out of a pile of parts. I looked up earlier discussions and found some that are over ten years old. There is reference to factory drawings that detail the specs on where the supports should be to correctly align the running boards so the fenders and apron will fit correctly.
Thanks.
I think you can find something useful here: https://modeltfordfix.com/the-1915-model-t-ford-part-1/
Last edited by williamcournoyer on Tue Dec 05, 2023 2:56 am, edited 1 time in total.
Post by DanTreace » Mon Dec 04, 2023 7:50 am
Here is a reference frame drawing.
http://www.cimorelli.com/mtdl/techarticles/Frame.pdf
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Mon Dec 04, 2023 8:36 am
Google "running board bracket jig, mtfca". It's a post on a jig Tom Rootlieb made to get your brackets perfect. There's a link with all the measurements to make your own.
Post by DanTreace » Mon Dec 04, 2023 8:51 am
Link to that post:
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=38189
popeyet
First Name: CHRIS
Last Name: MCINTYRE
Post by popeyet » Mon Dec 04, 2023 11:08 am
Thank you guys, this is great!
Chris.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Tue Dec 05, 2023 7:13 am
Running Board Frame Jig (2) (1).pdf
(36.43 KiB) Downloaded 179 times
