Distance from crankshaft to camshaft
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Tue Dec 12, 2023 1:16 pm
Anyone recall the centre to centre distance from the camshaft to crankshaft?
Dave
Last Name: Tannehill
Re: Distance from crankshaft to camshaft
Post by JTT3 » Tue Dec 12, 2023 2:40 pm
3.9375 I believe is the number you’re looking for.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Dec 12, 2023 3:20 pm
that is correct.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Tue Dec 12, 2023 4:06 pm
Otherwise known as 100 mm.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Dec 12, 2023 6:11 pm
Steve is Correct!!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Dec 12, 2023 7:02 pm
20-30 years ago I was trying to figure out what the correct gear spacing was. I had a perfect set of early straight cut gears and upon studying them I realized that they were essentially metric pitch gears and then the numbers worked out. I made some links to use for setting up my line boring and I got perfect gear mesh every time. No more need for off size cam gears!
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Dec 12, 2023 10:43 pm
"I read it on the internet, it must be true".
