Model TT enclosed cab windshield question
Etudes10
First Name: Greg
Last Name: Cosner
* REQUIRED* Type and Year of Model Ts owned: 1915 touring, 23 coupe, 26 speedster, 25 tudor, 25 TT
Post by Etudes10 » Mon Dec 18, 2023 5:26 pm
I need to replace the rubber weather strip on my 25 TT between the windshield and windshield frame. This is the lower fixed portion. I didn't see anything listed for this specific application from any of the vendors.
Curious what others have used.
Thanks, Greg
Added a picture of a couple small pieces that survived.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Re: Model TT enclosed cab windshield question
Post by JohnM » Mon Dec 18, 2023 9:05 pm
Looks like part number 7840D at Langs.
If you are not sure, you can ask on their website or call. They're always very helpful.
Etudes10
First Name: Greg
Last Name: Cosner
Post by Etudes10 » Wed Dec 20, 2023 11:40 am
Thanks John, I asked Lang's on their website. Part number 7840D is 1inch wide. The rubber from the TT is 3/4 inch wide. I will probably order and try trimming it to fit.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Wed Dec 20, 2023 5:22 pm
Greg... The rubber that's on the truck is original from the factory? Through the years, age, sunlight, drastic temperatures, and plain old atmosphere will tend to shrink rubber. Compared to what the vendor has, the new rubber is only 1/8 of an inch short on each side.... And after all these years, I'm sure the wood dimensions of the frame have shrunk a little also. Good luck on fitment of the new rubber.
