My engine does not have a hot air pipe installed and I have noticed the carb and intake runs cold and drips condensation even when it's 90 degrees outside So I figured it was getting fuel which left no spark. SO Today I pulled the Distributor cover checked the capacitor and the point contacts which checked Ok on the meter. I took some very fine "non graphite" sand paper and lightly sanded the contacts points. Hit the starter and it fired right up and purred like a kitten. I ran it for about 20 minutes adjusting the gas and timing to see best point for smooth running. Lots of funny smells and smoke from the year old dust cooking off the muffler and engine. carb and intake were dripping condensate like a leaky roof. engine ran cool with the water pump till I shut it off and the radiator starting making gurgling noises belching steam and water out the over flow for a half minute or so. Guess I had it too full.
First Start in over a year
Novice
Topic author - Posts: 639
- First Name: Jim
- Last Name: Davis
Novice
- First Name: Jim
- Last Name: Davis
DIAGNOSING starting problems. follow up first start
You can tell if a model T engine is getting fuel by checking the carb and manifold temperature to see if they get cooler after being cranked a number of times. not a cold weather test. But will help eliminate fuel as a problem So You can move on to check other areas. In My case dirty distributor points.
