'27 floorboard question
Brent
Topic author - Posts: 10
- First Name: Brent
- Last Name: Coil
- * REQUIRED* Type and Year of Model Ts owned: 1914 1917 1926 1927
I am working on my '27 Tudor. On the floorboard support angling up at the front, my car has a brass colored rivet on the metal support on each side. Any Idea what this would have been used for?
https://www.mtfca.com/phpBB3/download/f ... &id=180031
- Last Name: Humble
Re: '27 floorboard question
Those hold the carpet.
Mark Nunn
- Last Name: Nunn
My '26 Runabout does not have rivets there or holes for them.
Brent
- First Name: Brent
- Last Name: Coil
thanks so much
Open cars didn't have carpet.
Only thing on the rivet is if 'colored' like brass, may have been brazed at the factory, lots of brazing was done to secure things.
Check it with a magnet to test for steel.
Only enclosed cars got carpet as standard. Front carpet has snap fasteners to keep it down. The tabs on the side of the riser hold the kick panel in place, the rectangular pivoting plate holds down the floorboards.
But you could get rubber mat for closed cars for a while!
Moxie26
- Last Name: Jablonski
After installing all the floorboards use a screwdriver or pliers to turn that riveted piece of short metal horizontal. That was put in to hold the floorboards in place, helpful on washboard roads.
- Last Name: Patrick
Could that be the female half of a snap, installed by a past owner? The male half would have been installed on the floor covering and snapped down onto the female half to prevent the floor covering from blowing out. My 1926 coupe has snaps for holding the carpet in place. Jim Patrick
Upper photo is the male half. Lower photo is the female half.
jab35
- Last Name: Bartsch
My unrestored '26 coupe has those identical factory installed features, and of course, would have had the carpet too, thanks for bringing this information to the forum. jb
