Starter wants to fall off
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Sun May 26, 2019 9:01 pm
Hi all, it seems every time I get back from a drive my starter mounting screws are loose and the starter hangs with about a 1/16” gap along the top edge of the gasket. I can tighten it back down but it happens again and again. I’m not terribly worried about the starter, most starts are on the crank anyways, but I don’t like the thought of it probably losing some amount of oil every time.
What do you folks recommend to keep this from happening?
Last Name: House
Re: Starter wants to fall off
Post by George House » Sun May 26, 2019 9:15 pm
Lock washers? Is it possible you or someone else mistakenly used a smaller metric screw instead of 1/4”. ?
Post by RajoRacer » Sun May 26, 2019 9:22 pm
Starter mounting screws/bolts are 5/16" - if you're using the original screws, you might consider replacing them with a good grade 5 bolt w/new lock washers - at least you can get a decent wrench on the bolts.
Last Name: House
Post by George House » Sun May 26, 2019 9:34 pm
I stand corrected. They are indeed 5/16”...
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Sun May 26, 2019 9:54 pm
Would the effect of using 12 Volts add to this problem?
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Sun May 26, 2019 11:55 pm
I have the stock slotted screws and lock washers and have never had a problem
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Mon May 27, 2019 6:48 am
If lock washers don't do the trick, clean the threads out and use some blue locktite. But first check your bolts for correct size and thread pattern. I have picked up several at my local hardware store that have varied from batch to batch they have received. Take an original (if you have one) and match it up to the hardware store ones. Only way to know for sure.
Post by Norman Kling » Mon May 27, 2019 12:00 pm
Hopefully the threads in the hogs head are not stripped. If they are good and you are using the correct size bolts, use lockwashers and tighten them more. On my first T the first tour I went on, same thing happened to my starter! I didn't know why it would not work and used the crank. Anyway the tour was a "progressive lunch" so I drove on to the next stop and left a puddle of oil on their driveway!
Your problem is serious and you need to address it before you do much more driving. You could lose a lot of oil quickly which could lead to much worse problems.
Art McTevia
First Name: Art
Last Name: McTevia
* REQUIRED* Type and Year of Model Ts owned: 1924 Runabout
Post by Art McTevia » Mon May 27, 2019 12:06 pm
I used allen bolts. Easy to tighten.
Tiger Tim
Post by Tiger Tim » Tue May 28, 2019 8:45 am
Thanks all, I’ll be checking the threads in the hogshead (fingers crossed) and if they’re fine I’ll start with fresh lock nuts. Failing that I suppose I’ll try some loctite on the screws, or buy and drill some hex head screws so I can wire them.
Post by Mark Gregush » Tue May 28, 2019 12:25 pm
As was said above, unless the thread in the cover are bad, all you should need it lock washers under the slotted head screws.
