Anyone have an extrra ignition switch assembly?
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
Post by Dave_Kriegel » Thu May 30, 2019 7:05 pm
I need one quick to get a car ready for my Grandson to learn to drive in, All the suppliers are out of reproductions I have sent mine in for rebuild but if anyone has one for sale it will be appreciated I have posted also to classified with no takers
fxlew
First Name: Lew
Last Name: Morrill
Board Member Since: 2014
Re: Anyone have an extrra ignition switch assembly?
Post by fxlew » Fri May 31, 2019 10:04 am
Why wouldn't you just wire in some toggle switches until your switch assembly is returned? It is very easy to do.
Rick_Rice
First Name: Rick
Last Name: Rice
* REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Post by Rick_Rice » Fri May 31, 2019 10:56 am
Hi David,
I have a proper new reproduction ignition switch for you that I bought off of Lang's last year if you are in a bind. I also have the new bezel ring that is required for the reproduction ignition switch, as well as the improved lighted amp gauge that includes a needle that won't bounce. Feel free to call me on my cell to discuss.
Kind Regards,
Rick Rice....Cell (330)714-8151
Post by Original Smith » Fri May 31, 2019 11:01 am
Why not try the classifieds, or ebay.
Dave_Kriegel
First Name: David
Last Name: Kriegel
Post by Dave_Kriegel » Fri May 31, 2019 12:38 pm
Hi I have tried the classifieds I am bidding on the only available switch on ebay
Post by John kuehn » Fri May 31, 2019 12:44 pm
Have you tried Fordbarn? They have classifieds for T parts.
Rick_Rice
First Name: Rick
Last Name: Rice
Post by Rick_Rice » Fri May 31, 2019 1:46 pm
Well,
I guess you don't want the ignition switch assembly very bad. I have been sitting next to my cell phone all morning long and you never called. Please read the thread, see my response to help you and call if you are in need.
Kind Regards,
Rick Rice
Cell (330)714-8151
Post by Steve Jelf » Fri May 31, 2019 2:03 pm
If you already have a switch coming, I second the idea of a toggle switch from the local auto parts store while you wait. I believe they're around $5. You want a three-position switch: OFF, BAT, and MAG. If you intend to use the lights just add another: OFF, BRIGHT, and DIM, and an OFF-ON toggle for the tail light
Post by Mark Gregush » Fri May 31, 2019 2:19 pm
I wouldn't even bother with hooking up the mag, just off/on battery supply. By the way I sent an Email with another Ebay listing. If you want head and tail light, I would just add another off/on switch, hook the tail light and dim side to one terminal and power to the other.
For now I would just run a jumper to ground on the generator so it does not burn out if you chose to go that route.
