Rustoleum farm implement paint for block/head/pan?
NealW
Topic author - Posts: 524
- First Name: Neal
- Last Name: Willford
I'm getting ready to paint the block, head, pan, hogshead and various other engine parts on a T engine that I'm rebuilding. I was wondering if anyone has used Rustoleum's farm implement paint to paint these items, and if so, were you happy with the results?
The spec sheet for the paint says that it's good for temps up to 212 degrees F, and if the coolant system is doing its job, I believe that the head and block shouldn't get that hot. I won't be painting the exhaust with that paint though!
thanks,
Neal
thanks,
Neal
- Last Name: Hatch
Re: Rustoleum farm implement paint for block/head/pan?
What is wrong with engine paint?
- Last Name: Humble
I actually use farm paint for my tractor blocks, heads, and pan.
NealW
- First Name: Neal
Nothing! I couldn't get it locally in quart cans and the next couple of days will be warm enough outside that I'd like to paint all the parts before our winter temps come back. I picked up a can of the farm implement paint today, and was just wanting to see if anyone has actually used it on their engine parts before I did so.
Afrazer
- Last Name: Frazer
- * REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Hey Neal. I’ve used some in different applications and I thought it did fine. I’m trying some paint from a locally place this time for the block and head but I’ll paint the pan using the farm implement paint. Are you planning on brushing or spraying?
1925 closed cab TT
1926 two door sedan
1926 two door sedan
NealW
- First Name: Neal
I'm planning on using my HPLV gun. I'm also going to check with wholesale automotive paint in Wichita tomorrow to see if they have some engine enamel paint.
Afrazer
- Last Name: Frazer
I got my block paint from Auto and industrial paint supply in newton on broadway and it was ready to spray mix in a quart can and sprayed on really nice. I don’t know how it will hold up as I haven’t used them before.
1925 closed cab TT
1926 two door sedan
1926 two door sedan
signsup
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
The consensus on another vehicle forum I am active on is that the blocks should not get that hot to affect almost any paint. If it does, you got other problems. So, go for it. Here is my latest engine project painted Model A green.
I have had good luck using black stove polish on manifolds. Wipes on and will stay a nice matte black finish for over a hear. Then wipe on again. Available at ACE hardware here.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
I have used regular Rustoleum rattle cans, with no troubles. Once I used glossy, but hated the look and switched back to satin.
Tmooreheadf
- First Name: Tom
- Last Name: Moorehead
Magic farm implement paint from Tractor supply works well!
NealW
- First Name: Neal
After reading that I'd probably want to add reducer and hardener to the farm paint to get it to spray well and dry in a reasonable amount of time, I decided to just get another quart of Eastwood extreme chassis black for painting the engine parts. It sprays well right out of the can, and the cost isn't much more than buying farm paint plus reducer and hardener. Plus the paint is good to 330 F.
We had another couple of days in the 50s and 60s this week, so I got all the engine parts painted before it got cold again. Even in that temperature range, the paint dried pretty quickly. Time to start putting the engine back together!
Afrazer
- Last Name: Frazer
Took the same opportunity but used rustoleum and a hardener mix brushed on but took a lot longer to dry. Had the kid help on a cracked pan
1925 closed cab TT
1926 two door sedan
1926 two door sedan
