Center main bearing cap question
blauvelt
Topic author - Posts: 264
- First Name: Douglas
- Last Name: Ogden
Anyone seen a cap like this? Are the adjustments for thrust uptake?
Re: Center main bearing cap question
I have several types but not like that one !
Kerry
- Last Name: van Ekeren
With the 2 grub screws only to adjust one way, I'd say it's purpose is to close the mag gap.
It’s an adjustable main cap. A old trick to get you by with an original cap is to use a rat tail file and slot the holes enough to move it in closer. The best location to do this is with the rear main to lessen the end play.
RVA23T
- Last Name: C
I took the liberty to adjust the picture.
Craig Leach
- First Name: craig
- Last Name: leach
Hi Douglas,
This is one I picked up a few years ago, it's a little simpler design but should work the same. I would bet it was a fast repair for a otherwise
time consuming repair. Craig.
There is always something new here to see!
Thanks for posting these.
Adv for that type of cap to manage end-play.
And a couple of more devices to keep the mag strong
