Chevy rod bolt for T????
Last Name: Hatch
Post by Dan Hatch » Fri Feb 02, 2024 9:38 am
Does anyone know the part number or which engine the modern rod bolt is for T rods? Thanks Dan
Les Schubert
First Name: Les
Last Name: Schubert
Re: Chevy rod bolt for T????
Post by Les Schubert » Fri Feb 02, 2024 11:06 am
My personal opinion is a 3/8 Grade 8 unf bolt and tighten with a torque wrench to about 30 ft lbs. I grind a flat to the head so it fits perfectly.
Just my choice!
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Fri Feb 02, 2024 6:15 pm
Les,
Do you use a fine pitch thread bolt or a coarse pitch bolt.
Art Mirtes
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Feb 02, 2024 8:23 pm
Hi Dan,
Older small block Chevy rod bolts are the ones most use. They fit real tight, I hit them on the belt sander just a little so they will tap in.
I have a friend that builds Chevys & he replaces the rod bolts every time so sometimes & just get the used ones. I use the Chevy nuts also
I don't drill them for castle nuts. & use the lower Chevy torque specs. I think it's 40#.
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat Feb 03, 2024 11:21 am
Dan:
i do as les states above ... i turn the hex head and chamfer a standard 3/8-24 grade 8 bolt ... i machine the head only to have an appearance typical of the original rod bolt ...the grade 8 hardware is commonly available and has physical properties well in excess of the requirements of a connecting rod cap bolt ...and in my case this works better than a search for a supply source for a special fitting and the likely need to further modify that item or an associated component ... gene french
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Sat Feb 03, 2024 7:03 pm
I will add that I replaced the rod bolts in my 23 after I burned one rod bearing and had it rebabbited and sized with timesaver. I adjusted it at 30 ft/lbs but had to take out an additional shim on using a Chevy rod bolt at 40 ft/lbs. There was still a fair shim pack under the cap. I had previously replaced three original stripped bolts many years ago and decided to use all Chevy bolts to better balance the engine and didn't realize that the shim pack could compress that much with the additional torque.
Post by speedytinc » Sat Feb 03, 2024 8:54 pm
It probably wasnt the torque.
The mating surfaces have to flat mate together.
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Thu Feb 22, 2024 7:04 pm
IDK if this helps you but I found this:
https://www.summitracing.com/parts/arp-134-6003
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
