Trying to find info on this brass carb. Top looks like a Holley G, but fuel inlet looks like a Holley H1
Carb Identification
Mike.aanonson
Topic author - Posts: 1
- First Name: Michael
- Last Name: Aanonson
Model T Mark
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: Carb Identification
1912 style Holley. One of three variations that ford used in 12.
- Last Name: Tannehill
- Board Member Since: 2002
Holley H1, good carb once rebuilt (I suggest Corey Walker). You are missing a very expensive piece and that’s the fuel line pipe that forms the elbow at the male fitting on the bowl. Repairing those bowls,if you can, is a nightmare. Best John
That's a later version of the Holley H1. The earlier one had just two screws on the top plate. This 3 screw version suffered less distortion and made the carbs easier to restore. I too need the stepped screw on which the float arm pivoted.
