1927 Gas filter
Inthegarage
Topic author - Posts: 46
- Last Name: Mosher
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
1927 Gas filter
I ordered a gas filter from one of the suppliers https://www.modeltford.com/item/2903CSC.aspx
And by my surprise they are back ordered. Does anyone know of a filter that is a replacement. I really don’t want to cut up the fuel line and install a inline filter.
- Last Name: Patrick
Re: 1927 Gas filter
Snyder’s www.snydersantiqueauto.com, carries the delicate screen type gas filter for the original 1926-‘27 fuel sediment valve, part #9155-RK. It is listed in the Model A section but fits the 1926-‘27 fuel sediment valve. I don’t install the spring as it fits perfectly without it. Jim Patrick
Inthegarage
- Last Name: Mosher
Re: 1927 Gas filter
It shows out of stock
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: 1927 Gas filter
Supply chain problem at work.
- Last Name: Hatch
Re: 1927 Gas filter
Did you try other vendors?
Inthegarage
- Last Name: Mosher
Re: 1927 Gas filter
I’ve tried every vendor in the USA. I did come across one from England
help me find one.
Re: 1927 Gas filter
Oops… Did you call them? Sometimes it takes vendors awhile to get around to updating their websites. You can also ask them to put you on a call list whenever the item comes in. Jim Patrick
- Last Name: Hatch
Re: 1927 Gas filter
Smith and Jones? Did you try them?
Inthegarage
- Last Name: Mosher
Re: 1927 Gas filter
Snyders indicated a Model A part number A-9155-RK
try Mikes or other model a part suppliers https://www.mikes-afordable.com/product/A9155RK.html --
Try Gaslight https://gaslightauto.storesecured.com/i ... detail.htm --
Early Ford' $8.95 so they may have some https://www.earlyfordstore.com/products ... repair-kit
Google more places (some in the UK so watch it)
SOLD OUT at these places
https://cwmoss.com/products/sediment-bulb-rebuild-kit
TMiller6
- First Name: Thomas
- Last Name: Miller
Re: 1927 Gas filter
Tam’s and Bert’s are two more Model A suppliers to consider
Tom Miller
colonelpowers
- First Name: Joshua
- Last Name: Powers
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Re: 1927 Gas filter
I already sent Mr. Mosher an email but I thought that I would mention a part supplier that is probably on none of y'alls radar. Over in Unicoi, Tennessee is a Model A parts store. It has been there forever and he doesn't do anything online. Does primarily deal with Model A but he does have some T stuff stored away.
Anyway, the store is called Model A Mac's and the telephone number is (423) 743-5085. I don't think that he texts so you probably should call. He is a great guy and really knows his stuff.
God Bless and Happy Easter!
Inthegarage
- Last Name: Mosher
Re: 1927 Gas filter
I want to thank everyone for your help in trying to locate a filter. I’ll check out all of the suppliers that you have mentioned, and I’ll get back to you all
Model T Matt
- First Name: Matt
- Last Name: Madison
- * REQUIRED* Type and Year of Model Ts owned: 1923
Re: 1927 Gas filter
Just bought a vendor trailer full of stock hasn't been touch much in last 8 yrs have 4 of the A9155RK kits have to find out what a small flat rate box runs for you will hold one out and let you know Matt 503-824-2681
Model T Matt
- First Name: Matt
Re: 1927 Gas filter
looks like a flat rate small box is 10.60 and part is $4.95-so $15.55 total
