Engine numbers
BarrettR
First Name: RogerA
Last Name: Barrett
Engine numbers
Post by BarrettR » Sun Mar 17, 2024 3:55 pm
What year did they first start stamping engine numbers on the frame? Which side of the frame is correct?
Re: Engine numbers
Post by TRDxB2 » Sun Mar 17, 2024 4:32 pm
From the MTFCA Encyclopedia need to scroll down to answer https://www.mtfca.com/encyclo/C-D.htm#Chassis2
FRAME NUMBERS
Accession 94. Walter Fishleigh files.
“Motor number was first placed on frame side member R.H. on Dec. 12, 1925. Motor No. 12,861,044. Information obtained from Mr. Burns, Final Assy., Highland Park.”
Re: Engine numbers
Post by DanTreace » Sun Mar 17, 2024 6:05 pm
Could be either, some may be on the driver's side, most on passenger side upper frame rail by the running board support bracket.
