Anyone have an opinion about slotted bands vs pins, on the quick change ears ?
A preference ?
Quick change bands, slots vs pins
Re: Quick change bands, slots vs pins
Yes the pin style. I never really had good luck installing the slot type thru the door. The tabs seem to stick up and fowl on the pedal castings. To be fair, this has been on 25 back hog heads.
I've used both styles with no preference one way or the other. Most important, is to be sure they're in good condition, with NO cracks around the bases of the pins/tabs.
