Wire wheel ID
RadRacer203
First Name: Michael
Last Name: Stroz
Wire wheel ID
Post by RadRacer203 » Thu Mar 28, 2024 7:24 am
Picking up a '27 Touring in a few weeks, planning on taking the wire wheels and Ruckstell for my '26 coupe, then making it run and pass it along to someone else. I'm just curious if anyone can identify the wire wheels from a couple pictures, just want to make sure they aren't A wheels or something.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Wire wheel ID
Post by Kevin Pharis » Thu Mar 28, 2024 11:25 am
Look like T wheels to me
RadRacer203
First Name: Michael
Last Name: Stroz
Re: Wire wheel ID
Post by RadRacer203 » Thu Mar 28, 2024 12:28 pm
Ok thanks. I wish I had better pictures, but this is about all I have till I actually pick it up in a few weeks
Re: Wire wheel ID
Post by TRDxB2 » Thu Mar 28, 2024 1:41 pm
The first picture - does that wheel have front wheel brakes?
These are likely Model T since they are in a pile of T parts. But the one wheel has some rather large holes for studs
RadRacer203
First Name: Michael
Last Name: Stroz
Re: Wire wheel ID
Post by RadRacer203 » Thu Mar 28, 2024 2:17 pm
I know the seller said a couple wheels might be a bit damaged, so that could explain the larger holes on the one. As far as the front wheels go, I have no idea if it has front brakes. Would be nice if it did have front brakes, and those would definitely go on my coupe, but I'm not gonna hold out too much hope
jsaylor
Last Name: Saylor
Re: Wire wheel ID
Post by jsaylor » Thu Mar 28, 2024 2:53 pm
The Model T bolt circle is 5 inches. Model A is 5 1/2 inches with humps around the center. Hub cap is also larger. I believe a Model A complete hub and bearings will fit the the T spindle but you must add a locking nut to keep the bearings in place.
Re: Wire wheel ID
Post by Allan » Thu Mar 28, 2024 6:56 pm
They look like T wheels to me. A model wheels are easy to identify. They have a raised ridge pressed outwards between each stud hole. This stiffens up the hub so the wheels do not crack between the stud holes like some T wheels do.
RadRacer203
First Name: Michael
Last Name: Stroz
Re: Wire wheel ID
Post by RadRacer203 » Fri Mar 29, 2024 6:20 am
Ah, I see what you mean, I had never noticed that difference before, but that's very good to know
