Hi all.
I have a set of "Master" brand auxiliary wheel brakes that I picked up for my '17 Touring...minus any linkage. Is anybody familiar with Master brakes, and their linkage? Any information you could share would be helpful, minimizing any required wheel reinventing (or wheel brake reinventing).
Transferring motion from the pedal to the rear is not a problem, it's information about the linkage at the wheel that I'm looking for.
Thanks, Maury Dean
"Master" auxiliary brake linkage
m_p_dean@yahoo.com
Topic author - Posts: 60
- First Name: Maurice
- Last Name: Dean
- * REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
- Last Name: Strange
- Board Member Since: 2013
Re: "Master" auxiliary brake linkage
According to this old thread, Jeff Hood has (or had) a set of Master brakes for his car.
https://www.mtfca.com/discus/messages/1 ... 1322716197
At the bottom of this thread, Kevin Pharis mentions that the Master brake drums were cast iron, not steel.
viewtopic.php?t=29367
These photos of 'Master' brand were posted a while back. Seems to be similar to Rocky Mtn.
This older period adv of Master shows an artist drawing, not sure what the large rear casing part is about. The adv does mention cast iron drum, in two sizes 8" and 10" for heavier bodies.
