Hi all,
What suggestions do you all have for replacing the small brass plugs that seal the carb passageways? They're made of brass originally, I believe. Can I use heavy copper copper wire, or does it have to be brass? Thanks for your help.
John
Brass plugs in car. Passageways
Re: Brass plugs in car. Passageways
Stan Howe suggested using set screws for the next time https://www.mtfca.com/discus/messages/1 ... 1279536155
- Last Name: Hatch
Just be sure you don’t thread the screw in so far as to block the passage way.
Mark Nunn
- Last Name: Nunn
I had brass screws on a shelf that worked.
jab35
- Last Name: Bartsch
Copper wire of appropriate gage would be fine, many use brass filler rod. I've used brass rod 'tinned' with solder to insure a tighter fit.
I've had no trouble using Uncle Stan's method.
