1909 transmission
BernhardBK
First Name: Bernhard
Last Name: Klingels
* REQUIRED* Type and Year of Model Ts owned: 1909 Roadster, 1914 Speedster, 1919+1921 Doctor's Coupe, 1923 Roadster and Touring
1909 transmission
Post by BernhardBK » Fri Oct 18, 2024 6:21 pm
Hi,
Could someone give my any advise to a transmission from 1909? I heard that this should be different to a later transmission, but I do not know, how the transmission in a 1909 should look like.
Thanks a lot
Bernhard
Re: 1909 transmission
Post by Wayne Sheldon » Fri Oct 18, 2024 6:53 pm
Do you need information about just the internal transmission, gears and drums, including the flywheel? Or the whole unit including housings and linkages?
Also, for a 1909, there is a major change in the first half of the model year in how the car was driven, and in turn all the controls and linkages. While the internal gears and drums remained similar, the housings and linkages along with the control mechanisms changed in major ways.
Post by DanTreace » Fri Oct 18, 2024 8:59 pm
The initial 1909 Model T, up to about serial # 550, used a two-pedal arrangement for gears, the drums inside are similar to much later years, but the two pedal used a long handlever to engage reverse, so two levers, the other lever for emergency brake/clutch. Low pedal worked like later and brake pedal too. (Also up to about serial #2500 the motor was equipped with a water pump and gear driven fan)
Early Two-Lever, Two-Pedal
The after #550 or so, the change was made to use 3 pedals, and one hand lever, which continued til end of production.
Later Three pedal, One Lever
1909 trans.jpg (100.67 KiB) Viewed 1294 times
BernhardBK
Last Name: Klingels
Post by BernhardBK » Tue Oct 22, 2024 12:14 am
Thanks a lot, that’s exactly the information I was searching for. So, two brass lever was only for the very first ones.
Post by Wayne Sheldon » Tue Oct 22, 2024 4:46 am
I don't think anybody really knows just how many of the early Ts were two lever/two pedal. A lot of them were upgraded soon after the factory changed. Certainly, less than one thousand were manufactured with the two lever/two pedal system. Two lever cars I believe went somewhat beyond serial number 800, however early serial number 900s were showing up with the improved control three pedal single lever.
For whatever it is worth.
