I'm hunting for a front left fender for a 1927 T and have been offered a fender from a 1926.
Anyone know if this will be a matching fender for the '27?
Many thanks,
Joe
26 - 27 Fender Matching
Banjoe
Topic author - Posts: 153
- First Name: Joe
- Last Name: Lucas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
“We don’t do these things because they are simple, we do them because we thought that they were simple”.
- Last Name: Tannehill
- Board Member Since: 2002
Re: 26 - 27 Fender Matching
1927 T model short answer on the front fenders yes on all front ones. The model T ie coupe, Touring, roadster, Tudor sedan, Fordor. Coupe & roadster yes on all 4 fenders, I think Tudor & Fordor yes on all 4 not sure on the rear fenders on a touring but front is a yes.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Coupe, Roadster, Pickup rear the same Tudor Fordor, Touring rear the same. Mounting bracket came in two types for Coupe, Roadster, and Pickup, stamped steel, and a heavier bracket formed out of thick bar stock. Front all the same for both years. Only TT used the earlier pre 26 front fenders.
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
http://www.mtfca.com/discus/messages/59 ... 1456542578
There are some minor differences in the 1926 - 1927 front fenders over the course of production, just FYI.
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
Best I can remember, they are the same. If any difference, it would be the stamping where the headlights mount prior or after the headlight bar.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Gee, Y'all are making me feel like a 'Schmuck" pointing out all these MINOR differences in 26-27 front fenders. I've had SIX 1926-27's over the years, and except for one set on a 26 fordor that appear to have been "worked" so many times that the outer ridge on the fender is almost smooth and the fenders almost look like Model A's, I'd never noticed any MAJOR difference.ModelTWoods wrote: ↑Thu Apr 25, 2024 8:24 pmCoupe, Roadster, Pickup rear the same Tudor Fordor, Touring rear the same. Mounting bracket came in two types for Coupe, Roadster, and Pickup, stamped steel, and a heavier bracket formed out of thick bar stock. Front all the same for both years. Only TT used the earlier pre 26 front fenders.
Banjoe
- First Name: Joe
- Last Name: Lucas
Wow, I'm surprised that there are so many large and small differences between fenders. I'm going to get my 2 front fenders out and compare them with each other to see if they even match each other.
What a can of worms to sort through - or maybe just bolt on a replacement fender and call it close.....
Thanks for your feedback,
Joe
Joe
