Front End Friday
Topic author - Posts: 872
- First Name: Andrew
- Last Name: Clary
Front End Friday
This is popular over on Facebook.
Andy
Andy
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Re: Front End Friday
That surely is the face of the Model T. The first one has had "cosmetic surgery with skin grafts
- Last Name: Hatch
Here is one from the Heart of Dixie.
- First Name: craig
- Last Name: leach
No plastic surgery but some Botox. T shell would not fit over the square top forklift radiator.
Craig.-
- First Name: Austin
- Last Name: Farmer
Nothing inside just a radiator and hood.
- First Name: Ed
- Last Name: Martin
- First Name: Neal
- Last Name: Willford
The brass Baby Lincoln hood ornament on our 1915 runabout was a fun addition to the car.
- First Name: Bill
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: 2 each 1927 Tudors (Twins), 1926 Roadster Pickup, 1925 Touring Car, 1921 Depot Hack
Dan Hatch- that stuff makes me itch! And, not just on Saturday!
Bill
Bill
- Last Name: Hatch
Bill that is the good stuff, Virginia Creeper.
I have to stay away from the other.
- Last Name: Clary
I’d expect nothing less from you Steve.
Andy
Andy
OK - OK Andy - now it's Saturday & I couldn't decide which to post so you get both !
- First Name: DAN
- Last Name: MCEACHERN
- First Name: Chris
- Last Name: Bamford
1924 Speedster, still a few bugs to work out...
A Bugati Bug getter. How's the cooling ?
- First Name: Chris
Norm, the cooling, generally, is ‘way better than one might expect.
That is a 1938-tagged replacement honeycomb rad and it works very well. Most times I leave the fan belt so loose the fan hardly spins, and I only bring it up to operating snugness on very hot days or when a lot of climbing is expected.
The bugs you see are 2,000 miles worth — a badge of distance-honour that I cleaned off once we arrived home.
- Last Name: Clary
We’ll Chris, I’m guessing you had to brush your teeth when you got home.
Andy
Andy
Keep your radiator clean! Those radiators cool very well when clean, but due to the construction cannot be rodded out. They can only be boiled. Use a good rust inhibitor in it. Some of the old Plymouths and Dodges had that type from the factory.
- Last Name: Barker
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster
