Lang’s 26-27 roadster top bow wood set
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Post by fordt » Sun May 05, 2024 1:16 pm
Anyone bought these straight pieces from Lang’s lately? Can you relate how long they are and possibly how long the dimensions are supposed to be? I’ve researched it pretty hard and the consensus seems to be 36.5” front iron and 35.5” for the back pair (that’s length between iron, with an extra ~2.5” on each end to fit into the iron).
Last Name: Humble
Board Member Since: 2006
Re: Lang’s 26-27 roadster top bow wood set
Post by Humblej » Sun May 05, 2024 1:32 pm
Your windshield stanchions and clamps on the top irons will determine the length of the front wood bow. The others I cant help you with.
Post by speedytinc » Sun May 05, 2024 1:52 pm
The rest is easy. When folded down the metal bows 'nest" together.
fordt
First Name: Rob
Last Name: Trippet
Post by fordt » Sun May 05, 2024 6:32 pm
My windshield top irons are homemade, fabricated from other year top irons that I could find and made with the dimension help from this photo…
fordt
First Name: Rob
Last Name: Trippet
Post by fordt » Mon May 06, 2024 10:30 am
I really thought there’d be more improved roadsters out there to measure this….. :o
Post by DanTreace » Mon May 06, 2024 11:09 am
Here's the set of 3 ''26-'27 runabout new wood bows. The front bow is 36.5" long between the ends of the irons.
As your irons are home built, you may best resort to fitting the top clamps temporary to the metal iron and mount each on the windshield stanchions to really be sure of the overall length needed.
DCP_3042 - Copy - Copy (600x393).jpg (93.51 KiB) Viewed 1660 times
fordt
First Name: Rob
Last Name: Trippet
Post by fordt » Mon May 06, 2024 1:05 pm
Thanks Dan! I found that same picture in my searches, but for some reason I thought it was for a touring with 4 bows and wasn’t sure it would cross over to roadsters, although the cowl and such are the same! Now to hear from Lang’s bout their bow lengths as I’ve posted the question to them.
Thanks again!
Post by Norman Kling » Sat May 11, 2024 3:57 pm
Here is what I did. The center and rear were placed as received from Langs. The front I put on the irons with the clamps attached with bolt Then placed on the front stanchens
Put one enend of the wood in place and then tried the other. I adjusted the wood to fit either putting almost all the way in, or trimming off the end and extending the notch on the other. Once I got it to fit, I used bolts and nuts to hold in place. The part is wrapped anyway so the bolts don't show.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sat May 11, 2024 6:33 pm
While we’re talking measurements, is the outside to outside measurement on the front top irons (at front, just before the curve) the same as #2 and #3? Or does it go a little narrower or wider?
