I am looking for a Hand Brake Lever suitable for a '09/10 that is nice enough that I can have brass-plated. Bruce doesn't mention much about the structural differences between the years, and I didn't see anything in the Judging Guidelines either, -so is there any differences in the shapes of the lever (-not the cross-shaft or cam) that I should be looking for to look aesthetically correct??
TIA
Hand Brake / Brake Lever Differences...
BRENT in 10-uh-C
Topic author - Posts: 490
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: Hand Brake / Brake Lever Differences...
Past discussion with detailed picturesBRENT in 10-uh-C wrote: ↑Wed May 15, 2024 9:05 amI am looking for a Hand Brake Lever suitable for a '09/10 that is nice enough that I can have brass-plated. Bruce doesn't mention much about the structural differences between the years, and I didn't see anything in the Judging Guidelines either, -so is there any differences in the shapes of the lever (-not the cross-shaft or cam) that I should be looking for to look aesthetically correct??
TIA
https://www.mtfca.com/discus/messages/7 ... 1505093903
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Thank you!TRDxB2 wrote: ↑Wed May 15, 2024 10:45 am
I have two late ones. On one, the lever is straight, and on the other it is bent in toward the door.
One addition to my observations in the link Frank supplied. The flat headed clevis pins were also brass plated. I found traces of the plating on the pins of the assembly I discovered.
