Correct oil for Muncie transmission
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Wed May 22, 2024 2:43 pm
What oil should I be using in my Muncie auxiliary transmission?
Dennis Prince
Last Name: Prince
Re: Correct oil for Muncie transmission
Post by Dennis Prince » Wed May 22, 2024 3:22 pm
I use 140w gl-4, not sure if that is what it calls for but it has worked well for many years.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed May 22, 2024 3:27 pm
I run 85-140 & Ed AKA #4 the 600W Ed has way more miles than I ever will.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed May 22, 2024 9:15 pm
Redline Oil makes a synthetic heavy duty gear lube called Shock Proof. It has worked extremely well in my Chicago transmission. It runs cooler and is much quieter since I changed it over from conventional gear oil.
