Carburetor air leak?
Post by Steve Jelf » Fri Jun 07, 2019 12:28 pm
I think I know the answer to this, but I'll see if anybody confirms my suspicion. What is the likely effect of air leaking in around a worn throttle shaft? The carb in question is a standard NH, but I expect this applies to any similar carburetor.
Ruxstel24
Last Name: Hanlon
Re: Carburetor air leak?
Post by Ruxstel24 » Fri Jun 07, 2019 1:08 pm
Usually just a lean idle, or if really loose, idle may be too high. If you richen enough to idle good, probably too rich off idle...
Post by Scott_Conger » Fri Jun 07, 2019 5:01 pm
Dave
I agree with you and will add that generally, the idle will bounce around high/low every time the throttle is closed
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Fri Jun 07, 2019 9:36 pm
Had that problem as well until I had Russ Potter rebuild my NH. Trying to get a good consistent idle was constant challenge. Set it, idled OK. Drive down the road and stop...idle off and car runs rough. Also seemed like I was always adjusting the mix while driving as well. Under light throttle it had to be leaned, under full throttle it had to be enriched. Extremely annoying. After the Potter magic, the car has run beautifully. Idle stays consistent and under most throttle conditions (except for cold starts), I never need to adjust it. Some of the best money I've spent on my car. And yes, it had a worn shaft and mixture screw.
