Brake band adjustment
Topic author - Posts: 37
- First Name: Allen
- Last Name: Banks
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster
Novice question, but how do you tighten up the nut and have the washer follow so the notches line up? I tighten the nut but the washer stays put. ???
Re: Brake band adjustment
Yes, the washer is notched and stays in the pedal shaft slot.
Also - you will "feel" when the notch in the nut engages the washer protrusion - they're 180 degrees apart.
- Last Name: Hanlon
What Steve said, in other words, you can only adjust the brake and reverse half a turn at a time.
- First Name: Allen
- Last Name: Banks
Got it! Thanks guys!
