Late Carb Needle Tighten?
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Fri Nov 01, 2024 5:38 pm
How do you tighten a late carb needle? The carb is a sway back NH. The car is a '14 with the large brass disk on the other end which adjusts itself as I drive and not always the way I feel it ought to be adjusted. Lately I have been using a block of packing foam to hold it in place.
The '23 also with a swayback NH has a top nut that has grooves so it will tighten the needle as the nut is tightened into the casting. This nut has no grooves and does not tighten the needle no matter how hard it gets tightened.
Paul
Re: Late Carb Needle Tighten?
Post by Mark Gregush » Fri Nov 01, 2024 5:53 pm
You press the arms in a little to add drag to the needle.
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Fri Nov 01, 2024 6:23 pm
The arms press on the nut and not the needle unless I'm missing something. How would that keep the needle from migrating to a new position?
I know its gotta be simple but I still don't get it.
Paul
Last Name: Hatch
Post by Dan Hatch » Fri Nov 01, 2024 6:27 pm
Trust him it works.
Post by speedytinc » Fri Nov 01, 2024 6:31 pm
The pressure from the arms creates the friction so the needle wont turn on its own.
Post by Allan » Fri Nov 01, 2024 6:36 pm
The arms are part of the cross piece attached to the top of the needle. They are a unit. So just wind the needle out and pinch the sides in a bit. Job done.
Post by Norman Kling » Fri Nov 01, 2024 7:50 pm
If you can get the needle adjusted to the point where the engine runs smoothest when it is warmed up, but the needle moves as you drive along and gets out of adjustment, the arms needed to be tightened as Allan says. Then adjust to run smooth and it should stay in adjustment until you turn the nob.
Post by DanTreace » Fri Nov 01, 2024 10:15 pm
As posted by others, crimp the fingers over the cylinder of the lock nut to tighten drag of the spray needle. Easiest done by removing the needle, crimp some, re-fit needle , remove again and test and crimp to get the right tension.
Post by RajoRacer » Fri Nov 01, 2024 11:23 pm
I just today ran into a similar problem today with the late model NH repro adjusting needle - near 3/16" shorter than original and bottomed out on the adjusting nut to prevent the needle from seating to make a proper mixture adjustment. A couple minutes in the lathe to shorten the nut shoulder made for more adjustment.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sat Nov 02, 2024 10:39 am
I have the same problem on occasion. I have a 1-piece valve cover and oil mist from the throttle rod hole lubricates the fingers on the needle. Cleaning it is part of my normal routine.
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Mon Nov 04, 2024 2:58 pm
Thanks everyone, once I took a second look I could see what was happening and understand what needed to be done. No amount of clamping with the biggest channel locks I have would compress it enough to make any difference so the next step will be to remove the assembly and use the big vice. If that doesn't do it . . .
Paul
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Nov 04, 2024 3:03 pm
Paul, once you remove the needle from the brass nut, the fingers are easily bent to tighten their grip. Using channel locks with the fingers around the brass nut will do no good, but you already know that.
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Mon Nov 04, 2024 4:52 pm
Mark, thanks for the clarification. I knew I had no luck adjusting the tension but its good to know that just removing it will make the difference. I would like to retire the block of black foam under the dashboard knob.
Paul
