How much clearance?
michaelb2296
Topic author - Posts: 243
- First Name: Michael
- Last Name: Bunner
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
How much clearance?
How much clearance should there be between the rod cap and the crankshaft lobe? Skat crank has tight tolerances!!! Old cranks dont have this issue… lots of slop between journal lobes.
Kerry
- Last Name: van Ekeren
Re: How much clearance?
Ford specs are the crank is 1.505" and rod is 1.5" wide.
michaelb2296
- Last Name: Bunner
How do i sand .0025 off each end? Ford used a big damn file on the caps!
Kerry
Is the rod turning or binding?
michaelb2296
- Last Name: Bunner
Nope! New babbit. Not turning… super tight but does fit around the journal
Kerry
OK, usually it is the fillet cut that is tight, not cut deep enough to clear the fillet on the edge of the crank journal, but if you think it is too wide then rub the rod on a flat piece of glass with a sheet of about 320 sand paper. Run the rod bearing in with time saver.
Joe Bell
- First Name: Joe
- Last Name: Bell
I would rather have a large radius than a small one, less chance of breakage.
- Last Name: Tannehill
- Board Member Since: 2002
Amen Joe. As stated time saver will be your friend in fitting the rods on the journal, yellow 60 grit
