Copper Head Gasket
ChuckLebeda
First Name: Chuck
Last Name: Lebeda
* REQUIRED* Type and Year of Model Ts owned: 1919 Centerdoor
Copper Head Gasket
Post by ChuckLebeda » Fri Jun 14, 2024 2:35 pm
I am replacing a leaky head gasket with a copper gasket from Lang's.
Should I use any gasket type sealer on the head or just use the copper gasket without sealer??
Thanks,
Chuck
Re: Copper Head Gasket
Post by speedytinc » Fri Jun 14, 2024 2:43 pm
My method is 2 coats of silver spray paint on the gasket both sides.
The paint will soften when hot & fill minor voids but will come off in tact & be re-usable after a paint recoat.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Jun 14, 2024 3:31 pm
There is a copper headgasket spray from Permatex, I always use it.
Tim Williams
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Post by Tim Williams » Fri Jun 14, 2024 3:50 pm
I agree with jeff. use the copper head gasket spray.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Jun 14, 2024 4:22 pm
Copper coat can glue down the head gasket & make getting the head off an issue the silver spray paint if dry will not. I use the cheapest silver I can find. Not the looks like chrome stuff
Post by Norman Kling » Fri Jun 14, 2024 4:41 pm
I agree with the spray. also be sure the surface of the block and head are flat and smooth. Notice especially the area between cylinders 1 and 2 and between 3 and 4. Be sure the bolts are short enough to go all the way down to the head without the gasket. That will make it sure to crush the gasket when you torque the bolts. If they are too long the torque wrench will be measuring the torque between the bolt and the block at the bottom of the threads instead of holding the head down. I also put just a dab of Permtex heat resistant sealer around the steam vent holes in the front and back the head and block right next to the manifold. Don't put it anywhere else. just enough to keep the gasket from leaking at those two corners because the holes are very close to the outside edge and no bolts in that area. For an aluminum head torque when cold. For a steel head torque before you start the engine and then torque again after it reaches operating temperature. After you drive short distances torque again. Do this until the torque remains after driving it.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Jun 14, 2024 9:05 pm
Ford Service Bulletin:
Post by Jerry VanOoteghem » Fri Jun 14, 2024 9:49 pm
Me too! I use 2 heavy coats and install the gasket while still tacky.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Sat Jun 15, 2024 12:19 am
I use heavy coats of copper spray and haven't had any problems removing the head or any Leaks. I have a bunch of used gaskets still in usable shape. Alum spray is probably cheaper
1912 Torpedo Roadster
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Jun 15, 2024 12:44 am
I last used the copper spray, never tried anything else.
If you are asking that question then...Don't forget to chase all the threads. After I did so, I then ground off some of the tip of the tap and chased them again. Had bought a new tap for this purpose but cut the used tap instead.
Vern (Vieux Carre)
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Jun 15, 2024 12:46 am
And Norm filled in all the blanks ;)
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Sat Jun 22, 2024 7:36 am
As for the "silver" spray try aluminum color paint. It typically is made with aluminum in it. The aluminum will work to seal better than just silver spray.
