21" split rim latch bolt?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Jun 27, 2024 3:08 pm
This rim is missing the latch bolt. It looks to be a 5/16" x 24 tpi thread. Does it just use a short bolt and washer?
Thanks,
Keith
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: 21" split rim latch bolt?
Post by Humblej » Thu Jun 27, 2024 3:25 pm
Just a sloted round head screw.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Jun 27, 2024 4:23 pm
Then just flush on the under side?
Post by RajoRacer » Thu Jun 27, 2024 4:45 pm
I might add to Jeff's description - it's a rather LARGE round head slotted screw - no washer needed !
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Jun 27, 2024 5:00 pm
Satisfactory for git 'er done?
First Name: john
Last Name: karvaly
Post by speedytinc » Thu Jun 27, 2024 5:05 pm
Been a while since I have seen an original screw.
I recall it looks a lot like an early cam bearing retaining screw.
Tekirgis
Last Name: Kirgis
* REQUIRED* Type and Year of Model Ts owned: 1926 fordoor
Board Member Since: 2024
Post by Tekirgis » Thu Jun 27, 2024 6:35 pm
The bolt/ screw was available at langs, I bought a couple a few months ago
First Name: john
Last Name: karvaly
Post by speedytinc » Thu Jun 27, 2024 6:44 pm
Thanks for the info.
$4.95 thru Langs.
