Model T Emergency Brake Lever/High / Netural Lever
OleGeorge
First Name: Rustin
Last Name: Nanninga
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Touring Non Electric Car
Post by OleGeorge » Sat Jul 13, 2024 7:57 pm
So I have been noticing on my 26 T Touring that when I need to use the Brake Lever all the way back to stop sometimes I am getting what sounds like a dry squeak sound when I pull it back all the way. Any ideas on what is going on. We have Owned the car for now 20 Years. I have had never had the rear wheels or brake drums off. The previous owner basically used the car as a Museum Showpiece so he did not drive it much. The previous Owner before him I do not know much about.
I do not know if I need new brake shoe linings or etc.?
Thanks.
Kerry
Last Name: van Ekeren
Re: Model T Emergency Brake Lever/High / Netural Lever
Post by Kerry » Sat Jul 13, 2024 8:01 pm
Is there something wrong with the trans brake that you are using the hand brake to stop?
Post by Wayne Sheldon » Sat Jul 13, 2024 9:02 pm
A 1926 touring car should have the improved T large drum lined brake shoes, and if properly maintained and adjusted can be used as an emergency brake or brake assist to save a bit on wear of the pedal brake linings.
The lining can dry out with age or wear with use. A squeak could be from many things, including hardened linings or wear allowing a metal part of the shoe to contact with the drum.
Regardless, it is only speculation without pulling the wheels and taking a good look at things.
You may need a wheel puller to get the wheels off. What type wheels does your T have? Wire wheel hubs and wooden spoke wheels use different types of pullers. If a proper puller is not readily available, there are other ways to loosen the hubs.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sun Jul 14, 2024 7:09 am
Might be a good time to pull your bands to inspect your linings and pull the rear wheel to inspect the parking brake shoes.
Last Name: Hjortnaes
Post by DHort » Sun Jul 14, 2024 5:07 pm
Rustin
You should be taking the rear wheels off every 1-2 years to inspect and repack the rear bearings, and examine the sleeves and the rear axle. This is just standard maintenance. You should do the same with the front bearings. Are you also oiling the front and rear axle shackles and greasing the universal joint?
OleGeorge
First Name: Rustin
Last Name: Nanninga
Post by OleGeorge » Sun Jul 14, 2024 11:22 pm
I grease the U Joint and Drive Shaft Zerks as recommend. Also, oil the shackles, etc. I have not taken the rear wheels off. Will I need a puller to get the Rear Wheels off?
Thanks.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Mon Jul 15, 2024 12:39 am
How about your hand brake cross shaft? Maybe it needs a little oil.
http://www.mtfca.com/discus/messages/33 ... 1374983789
Last Name: Humble
Post by Humblej » Mon Jul 15, 2024 6:33 am
Yes, you will need a puller or a wheel knocker to get your rear wheels off the axle shaft.
Last Name: House
Post by George House » Mon Jul 15, 2024 1:46 pm
I’m with Burket..The Crossshaft onto which the emergency brake handle is riveted is held by 2 brackets - one on each frame rail. There’s a hole in each frame rail into which oil can be squirted onto the Crossshaft. That could also cause the ‘dry squeek’
OleGeorge
First Name: Rustin
Last Name: Nanninga
Post by OleGeorge » Mon Jul 15, 2024 2:26 pm
Yep. I give it some oil from time to time as well. Thanks for the heads up everyone. I think since the last time I oiled that area I have noticed the squeal being gone and the lever and etc. moves much more freely.
