carburetor rebuild services?
aDave
Topic author - Posts: 354
- Last Name: Dufault
Now that Stan & Russ have gone to their rewards, who is rebuilding NH Carburetors? I've got a straight thru that needs a little more TLC than I feel capable of giving it.....i.e. "hidden passages".
I couldn't find an ad in the Vintage Ford nor in the Classified page on the Forum. Did I miss some folks?
Thanks.
Dave
Thanks.
Dave
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: carburetor rebuild services?
How about Corey Walker
He posts frequently here
schwabd1
- Last Name: Schwab
From what I understand Russ’s son is going to continue carrying the torch on the non brass carbs, but not the older brass bodied carbs.
Ron Patterson
Corey Walker worked on an problematic early Holly G for me that had a strange problem and it now works great.
He has my vote/recommendation.
Ron Patterson
Ron Patterson
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Jim Potter has been working in the shop with Russ for several years rebuilding T carburetors. I would not hesitate to send him a rebuild job.
J1MGOLDEN
- Last Name: Golden
Jim Potter's usual Ad is on Page 59 of the MAY/JUNE 2024, MODEL T TIMES.
aDave
Thank you everyone.
Dave
Dave
Loftfield
- First Name: Thomas
- Last Name: Loftfield
Jeff Dreibus in Nebo. North Carolina does carbs under the business name Old Carb Doctor. Can be reached online at Old Carb Doctor. He has done several Model T carbs as wells Scheblers for Buicks for me, always excellent work.
